I am using Revit 2022. I generate new families with generic, furniture, floor, or something similar type templates. If I hover over Create on the ribbon and hover over extrude and hover over type of extrusions it gives description but also says there is some type of vid issue not showing the simple examples of each extrusion type in ribbon. I know what each one does but just don't like the fact that something is not working right. Any ideas for a fix. I turned off default vid card so my other/better one was only to be used with no luck. That tactic works often in many apps/games.
Are you saying you do not see this little video that plays showing the creation process? You could try turning off hardware acceleration, go to File --> Options --> Hardware --> uncheck "Use hardware acceleration"
Options=>User Interface=>Tooltip Assistance.
