Revit 2022 educational version asks for serial number but account shows "Sign in"
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
9026 Aufrufe, 5 Antworten
I have installed Revit 2022 educational version and it ran as a trial version first ,now that the trial period is expired Im asked to enter a serial number to activate the software and in the product page it says that the activation method is by "sign in " I cannot even run the software to be able to sign in .
Thank you.
Beschriftungen (1)
5 ANTWORTEN 5
Nachricht 2 von 6
RDAOU
als Antwort auf: Anonymous
@Anonymous
What are the options you get when you select enter license number? are you given the option to change license type or login?
Did you receive the confirmation email from education community that your Autodesk account has been granted access to Revit 2022 Educational license
See also this post
https://forums.autodesk.com/t5/revit-mep-forum/can-t-enter-serial-number-when-activating-revit-2020/td-p/9497022
Nachricht 3 von 6
als Antwort auf: RDAOU
@RDAOU
-When I click on the option on the right "Use a network license " I am then asked to specify a license server .
-Yes I have received an email from Autodesk confirming my educational access to Revit 2022
Thank you
Nachricht 4 von 6
RDAOU
@Anonymous
I was referring to the serial number.. the one on the left.
On the image u posted...there is a gray notice that you are not able to connect to Autodesk licensing services...and that your internet settings seem to be blocking the log on
  • Disable any firewall
  • Make sure you are connected to the internet
Then the dialog which pops up should give u the option  to change user... that is where u log in with ur student account ..see image below
Nachricht 5 von 6
Thank you @RDAOU It worked !
Nachricht 6 von 6
Abdifatahfarah753
Serial number and acti
