Revit 2022 - Command Prompt continues to appear whenever Revit is open
vcio
vcio
The installation of Revit 2022 has been successfully completed. However, the Command Prompt (black screen) continues to appear unexpectedly whenever Revit is open. Kindly see attached file for your reference.
[The subject line of this post has been edited for clarity by Community Manager. Original: Revit 2022 - Unable to Use]
jay_colcombe
Please take a look at this Knowledge base article
SQLDUMPER.EXE window opening and closing when launching or working in Revit or Advance Steel
This thread may also help
Solved: When opening Revit cmd continuoysly opens. - Autodesk Community
Jay Colcombe
Autodesk Certified Instructor
mari.shimode
Hi @vcio, did you find the information provided useful? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Mari Shimode
mari.shimode
Hi @vcio, I believe you can solve the issue with the information provided. I have marked @jay_colcombe's reply as an accepted solution so others who have the same question can find it easily. Please visit the Autodesk Community again when you have any other questions.
Mari Shimode
