Revit 2022: Blue arrows when using Revit move, copy, or rotate command.
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
tsnedakerV9YRF
381 Aufrufe, 6 Antworten
Hey Revit Forum,
In the last few weeks I've had these arrows pop up when I use the Revit's move or copy commands, and maybe other commands too, but definitely those two. Is there a way to turn these off?  Thanks in advance.
Beschriftungen (2)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: tsnedakerV9YRF
Those look like temporary dimensions. If so, they should be scaling.  Maybe Graphic Card issue. Turn off Hardware Acceleration.
Nachricht 3 von 7
tsnedakerV9YRF
Thank you. I wonder how to turn off the Hardware Acceleration?
Nachricht 4 von 7
Nachricht 5 von 7
tsnedakerV9YRF
Thanks again. I really appreciate it.
Nachricht 6 von 7
tsnedakerV9YRF
Is there a way to affect the entire amount of documents in my revit file or selected sheets?
Nachricht 7 von 7
tsnedakerV9YRF
Hey Forum,
I'm still getting the blue arrows and they constrain movement. Any other ideas?
Thanks!
