Is it possible to Batch Print a set of drawings to a single PDF?
When printing normally, there is the option to "Combine multiple selected views/sheets into a single file." I would like to do this with a Batch Print, but do not see the option. It currently prints the sheets to individual PDF files.
For context - I'm looking into Batch Print rather than printing normally because I would like to adjust the order of my sheets (My demo drawings, labeled as SD___, are getting pushed to the end of my set. The other drawings are all labeled as S___ ). I can adjust the order in Bluebeam afterwards, but looking to see if I can just get it to print correctly straight from Revit to a single PDF.
With the Docuflow plugin you can publish multiple sheets to a single PDF, set the order of the sheets, etc. The advantage over the Revit sets is that it will remember the sheet set order.
See more here:
https://apps.autodesk.com/RVT/en/Detail/Index?id=6842090281765127625&appLang=en&os=Win64
Thanks for the reply ToanDN!
This approach publishes the sheets in alphabetical order, so it yields the same result as printing to PDF. I don't see an option to reorder the sheets before exporting.
You can use Re-Order Sheets tool in pyRevit.
Create a Sheet list based on the Order parameter.
Then use pyRevit Print Sheets:
