In attempting to resolve some issues with Revit and 3D/Realistic Views I'm trying to apply the 2022.1 Hotfix. When I run it, it says it was successful but I do not see the Build Version change in Revit, nor do I see the File Version for Revit.exe change at all either. I'm confused. Has anyone else seen this?
I already told you I've checked that, and it's not changing after the Update.
Perhaps you should tell us what "issues" you are hoping the hotfix will resolve. I'm not seeing any fixes related to 3D/Realistic Views.
Yes, 22.0.2.392. That's also the same build as machines that didn't receive the Hotfix and these installs were built in July/August.
GO to Control Panel >> View Installed Updates >> Type the keyword Revit 2022.1
If you do not see the update installed =>
It's the right update and I have full permissions. It must be because it doesn't have access to the original content path, which wouldn't be the case for most centralized deployments. I'm not sure if there is a way around that or not.
