Revit 2022.1.5 Central Model Regens while trying to Edit Objects
2 ANTWORTEN 2
Nachricht 1 von 3
tturnerJBN46
160 Aufrufe, 2 Antworten
Revit 2022.1.5 Central Model Regens while trying to Edit Objects. This shows up in the bottom left corner (Image attached). It only is happening in one Model in Revit 2022. But it can take up to a minute.
2 ANTWORTEN 2
Nachricht 2 von 3
Alfredo_Medina
als Antwort auf: tturnerJBN46
Most likely you have some views that need more time to be processed, due to the settings of the view, such as: depth cueing, shadows, realistic mode, sketchy lines, and similar. If you want Revit to move faster, avoid those things during daily work, and use them only for presentation, being aware that those views will take longer to regenerate.
Nachricht 3 von 3
tturnerJBN46
I looked through the Model with the Regen issue. I do not see any of those type of settings turned on in the Views (Mainly View Templates). Any other suggestions ?
