[Revit 2021] What is the wrong with the material Browser?
7 ANTWORTEN 7
Nachricht 1 von 8
979 Aufrufe, 7 Antworten
The CPU is rendering the texture.
This did not happen in previous versions. Has that changed? Is it possible to change this loading?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Same thing happens to us. They eventually show up though. It's a little aggravating.
Following.
Just to clarify; I'm referring to the swatches not loading promptly.  Is that what you mean?
Nachricht 3 von 8
als Antwort auf: barthbradley
Yes!
CPU usage is at 100% when viewing materials ...
My CPU is 10900K.
Until Revit 2019 this did not happen.
Nachricht 4 von 8
alesisvillo
im having the same problem, cpu gets to 100% in a sec. and around 95c  but as soon as close that material browser it returns to a normal temp... its starting to freaking me out... and its a brand new "high end laptop"... 10750H processor
Nachricht 5 von 8
als Antwort auf: alesisvillo
Nachricht 6 von 8
autodesk does not solve this problem. this is too boring. every time it loads the CPU usage on the materials.
Nachricht 7 von 8
alesisvillo
changin the filter to display only list view, works quite well actually... temp stays normal. Also i think i noticed this happens too when the edit perimeter command is active
Nachricht 8 von 8
lshannonEQEBT
We are starting to see this issue on some of our projects now too. It's gotten to the point that the legacy materials won't even load a preview of the material in the Appearance tab.
