Revit 2021 Stair Treads/Riser Number not working in Sections/Elevations
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
jiruzubieta
2264 Aufrufe, 2 Antworten
Hi there,
I'm dealing with an odd issue when trying to number treads in sections. The Stairs come from links and numbers are showing up far away from the stair position in Elevation and Section views. Any clues?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: jiruzubieta
Weird. Would it be possible for you to post the two files for us to examine?
Nachricht 3 von 3
jiruzubieta
Hi Barth, I've already got to the bottom of it. Is to do with the Internal Origin of links. Pretty weird one as Revit could handle this in a much smarter way detecting the rotation difference between Internal Origins (Master models and link) and hence positioning the treads/riser numbers where the stairs are, not far off. One of the incomprehensible Revit glitches to add to the list.
