Revit 2021 material library missing
10 ANTWORTEN 10
Nachricht 1 von 11
joshlim0918
1630 Aufrufe, 10 Antworten
Good day ! I would like to ask how to install or load the missing materials on Revit 2021? It says that one or more texture files cannot be found and there is also an orange exclamation mark beside the materials.Capture.PNG
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: joshlim0918
That little triangular orange symbol just means that the Material is using a Legacy Appearance Asset as opposed to the newer PBR Appearance Asset.  All's good.
...and to see what textures are missing, go to the Appearance Tab of the specific Material. You'll probably see this:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/E...
Nachricht 3 von 11
ennujozlagam
you can try to refer to this ARTICLE and see if helps. thanks
Nachricht 4 von 11
joshlim0918
als Antwort auf: barthbradley
Nachricht 5 von 11
@joshlim0918 wrote:
I'm confused all of the mats are not flat images.
me too. it was better in the olden days.
Nachricht 6 von 11
joshlim0918
Should I just use an older version of Revit or is there a solution to this?
Nachricht 7 von 11
What kind of solution are you seeking?
Nachricht 8 von 11
joshlim0918
Like if can still use the legacy textures?
Nachricht 9 von 11
What's stopping you, @joshlim0918?  Nothing should be preventing you from using Legacy Materials.  What's going on at your end?
Nachricht 10 von 11
I think you are just a bit confused by the UI. We were all confused when Revit introduced those ominous-looking, triangular-shaped markers on the Material swatches.
Nachricht 11 von 11
joshlim0918
How do I find the missing texture files?
