Revit 2021 issues
2 ANTWORTEN 2
Nachricht 1 von 3
hughecchapman
268 Aufrufe, 2 Antworten
Revit 2021 issues
I have a project which needs to stay in R2021 to ensure compatibility with the rest of the design team.
I currently have two issues with R2021 I can't work out how to resolve:
1) The properties tab is not visible. I've tried everything suggested here except re-installing Revit 2021 which seems to be the 'nuclear option'.
2) Revit won't let me link dwgs. I get this error message
I close this message (twice) and then get this error -
Can anyone help me with these issues?
Many thanks
2 ANTWORTEN 2
Nachricht 2 von 3
SteveKStafford
als Antwort auf: hughecchapman
Regarding the properties palette, check your graphic card/Driver compatibility in the Options dialog. What does Revit "think" of the graphics card/driver? Are you using a Display Scale greater than 100% in the operating system?
When you attempt to link a DWG are you using the option to specify the Units instead of using the Auto option. Does this happen with any DWG file or just specific one(s)?
Steve Stafford
Nachricht 3 von 3
hmunsell
From what I understand of the licensing, you have another Year and a half . I believe you'll loose 2021 when 2026 comes out? maybe its 2027...
Well @SteveKStafford took most of my questions :Gesicht_mit_Freudentränen:
Only other thing I'd ask is are you trying to link directly from dropbox? or are you copying the DWG's to your project first?
Howard Munsell
