Revit 2021 is Unresponsive
3 ANTWORTEN 3
Nachricht 1 von 4
lshannonEQEBT
542 Aufrufe, 3 Antworten
I have been having this issue where after a little while, the whole interface becomes unresponsive. I can move my mouse around and the model in the view, but I end up not being able to do any command. Left-clicking on buttons and menus highlights them and clicks them, however the commands do not register a response. It is so bad that I cannot even exit from the program, either by clicking on the "x" in the top right or "Exit Revit" in the File menu. I have to force close it with the Task Manager. The scariest part is that it will not let me save either. What could be causing this?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: lshannonEQEBT
Nachricht 3 von 4
lshannonEQEBT
als Antwort auf: barthbradley
@barthbradley
This is a good idea. I will have to see if my IT team can do it since we install with network packages.
Nachricht 4 von 4
ennujozlagam
try to update your graphics card driver and have you try to untick use hardware acceleration from options and see if helps. thanks
