Revit 2021, Imperial Construction Level 2 Missing Elevation
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
keepontrying.ourworld
491 Aufrufe, 4 Antworten
I have run into an issue only present in the imperial construction project group. When I open an imperial construction file and go to level 1, the elevations show up. When I change to any other level however, it is a blank page. When I make a new level, the elevations are present. However all other levels but level one are blank. When I go into my visibility settings, elevation is checked. The view range is not cropped. Nor is the crop region small. I am unsure of what is happening.
4 ANTWORTEN 4
Nachricht 2 von 5
I just reopened a new project and tried manually placing an elevation on level 2, t.o. footing, etc. it worked. But why is Revit not automatically creating elevations for each level?
Nachricht 3 von 5
Check your View Phase.
Nachricht 4 von 5
Nachricht 5 von 5
So strange worked immediately. I had changed the view phase earlier but it didn't work. I tried again this time and they just appeared when I moved it to project completion. So weird but thank you!
