Hi Revit community, I have an issue in my revit program. I downloaded Revit 2021 and it normally functions on my upgraded pc very well but while I was working on a project, I am having issues to load a curtain wall door. I need to put doors to the curtain wall, I am not able to load a family because the the program thinks that I am still in windows. It shows me the warning in the attached file. I tried out few things like restarting the program and windows but it doesn't help. Do you have any idea why is that so? And what can I do?
Thanks in advance for your help.
Best Regards, Seda
I just had a similar problem. I can't load the door families I need because they weren't included in my Revit2020 download for some reason. I don't have any US metric doors, except one commercial revolving door. Was this the same problem you had?
-Jeff
TAB-Select the Curtain Wall Panel, Unpin it and then select a Basic Wall Type to replace it with from the Preview drop down. After swapping out CW Panel for Basic Wall, you can place instance of that Door Family you are showing on the Wall via Architectural Tab: Door.
Hi, I don't think so. My problem is to load a door to the curtain wall and and that my PC doesn't allow to load the curtain wall doors. ![]()
