Revit 2021 - Export LandXML
4 ANTWORTEN 4
Nachricht 1 von 5
KristianKvistgaard
2515 Aufrufe, 4 Antworten
Hi
Since Site Designer no longer will be an Autodesk Add-in, how to export to LandXML
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: KristianKvistgaard
Nachricht 3 von 5
@barthbradley, the question was how to export :zwinkerndes_Gesicht:
Nachricht 4 von 5
Jim_Melin
I would also like to know this.
For some unfathomable reasons landscape architects have begun drawing in Revit, but they don't share their terrain data in any useful formats for Civil.
Meshes exported from Revit in DWG format are not reproducable safely in Civil and even worse since the introduction to Toposolids from Toposurfaces in Revit 2024 since it doesn't cut out subregions from the man topology and only places them above it ad distances larger than 1 unit (mm for instance).
Tips about better ways to export topodata from Revit in general would also be helpful
Kindly
Jim Melin
AEC AB CAD Solution Support
_______________________________________
www.aec.se
Nachricht 5 von 5
Haider_of_Sweden
als Antwort auf: Jim_Melin
Hi Jim,
Two years later ... here is a solution, called Environment for Revit, an add-on that offers many solutions, among others export LandXML and it supports importing Civil3D data as well. I have used it and it works well.
Another tool is ReOpe Toolbox for Revit - scroll down a bit to the LandXML-part
https://reope.com/toolbox
I haven't tried it out yet.
If anyone has something new to add, please do so.
