Revit 2021 Crash and after certain views blank with no resoltuion.
2 ANTWORTEN 2
Nachricht 1 von 3
404 Aufrufe, 2 Antworten
Hi, a student of mine is having a serious issue that I have been unable to resolve with Revit 2021.  An audit of the file turned up nothing.  She experienced a crash for an unknown reason and upon reopen all plan views except one and all elevation views are blank.  I have confirmed there are no phases (only one) - no VG overrides - no hidden objects - no visibility filters applied - no design options, no crop boundaries on the views although there does seem to be som crop boundary bugs apparent but playing with setting does not achieve a resolution.   Zoom extents does not change the problem - creating a new scope box does not change the problem.
The sections and 3d views do contain content still and so I have verified that there are entities that should be visible in plan and elevations - and they previously had been visible as normal according the student prior to the crash.  Previously opening up a backup file had restored her views but now she says even that is not working.  I'm not sure what happened to her but if someone can help me investigate the problem I would much appreciate it.
The file is too large to upload on this forum but I can provide a download link:
https://www.dropbox.com/s/htc2vk1zqann2gh/Barragan%20Residential-3.rvt?dl=0
Thanks all!
Adrien
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Any backups?
Also, can you ZIP the file and post as an Attachment?  How about the Journal File too?
Nachricht 3 von 3
als Antwort auf: barthbradley
@barthbradley Hm, the file size is 96 MB and the zipped version is 95 MB haha...  I do not have access to her back up flies but as noted she said opening the backups no longer work for her and anyway that is not really an acceptable solution to lose work each time this issue occurs.  I'm not sure if the journaled file is a type of export from revit or what - if you think that is helpful please explain.
I did actually just discover a work around if anyone else is experiencing this.  I created a new scope box from the one plan view that showed objects - then set every view that was blank to reference it in it's veiw properties - this alone did nothing, so then I also set all the levels to reference the scope box by selecting all the level symbols from the 3d view.  This seems to have reset the plan views at least.
This seems like a serious issue the developers should take a look at.
