Hi everyone,
I am having issues with REVIT 2021 on some machines it does not export IFC.
The settings are all the same.
Any ideas?
Cheers!
Gelöst! Gehe zur Lösung
Gelöst von spahlevan. Gehe zur Lösung
@barthbradley wrote:
Thanks for the reply!
These files are rather small and there is no Hanging or freezing. Its very quick with no Error or warning and results in no IFC generation!
Side note: Verified and it is not about the wrong path or directory were I should be looking for the exported file.
However on a different machine it is different, the process takes few seconds, meanwhile on the Status bar counts the objects as normally it should during the export process, and generates the IFC.
Cheers!
In order to export IFCs sometimes need to install the relevant version of IFC app from the Autodesk App Store to be able to Export IFC.
In this case IFC 2021:
https://apps.autodesk.com/RVT/en/Detail/Index?id=7265544480016320144&appLang=en&os=Win64
