Revit 2020 won't download- 'missing something' then closes
samuelzergling
samuelzergling
Tried standard download and it says, after installing... like... 25 of the 26 'things' that something is missing, and offers me no other insight. The only thing to do is close. I tried browser download and get this.
luna.ye
Autodesk Support
Autodesk Support
Hi @samuelzergling,
This message means that a necessary Revit installation file is missing, and the download fails as a result.
There should be seven installation packages for Revit 2020, please check if you have downloaded all contents of following image.
If not, follow these steps:
  1. Disable popup blocker on your Internet browser.
Note: If using Internet Explorer, once product installer download initiates, instead of clicking Run button, click Save button.
  1. Make sure all parts of the installer are saved all in the same folder.
  2. Then, run any of the EXE file.
Or try to download from Autodesk Virtual Agent, refer to the solution in:You encounter issues when you try to download Autodesk software with multiple files .
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Luna Ye
Product Support
I have just tried to download this way but only 6 of the 7 files downloaded, any ideas on why this is? Thanks
