Revit 2020 - Windows projecting (ghosting) on to floor.
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
keri_salim
1099 Aufrufe, 11 Antworten
Has anyone ever dealt with this? I'm a CAD/3D modeling tutor and I have had to help students fix all kinds of weird things in Revit but I've never encountered this before. I'm assuming it's a setting but I can't find it. Please take a look at the image attached. I've hidden one of the walls for clarity.
11 ANTWORTEN 11
Nachricht 2 von 12
syman2000
als Antwort auf: keri_salim
Can you upload the sample file?
Nachricht 3 von 12
keri_salim
Attached the student file
Nachricht 4 von 12
keri_salim
Trying again. The attachment doesn't show up on my end.
Nachricht 5 von 12
It's coming from a nested family in the Window Family.
Did you look at your Window-Casement-Single_Left.rfa Family?
Delete this and reload Family into Project.
Nachricht 6 von 12
syman2000
I check the family. Apparently your muntin is replaced with trim family. If I switch it to 2x2 Mutin, it display properly.
Nachricht 7 von 12
Nachricht 8 von 12
keri_salim
als Antwort auf: barthbradley
That worked but the question is why did it happen? It did it with all the types that the student placed. It did not do it when I placed a different type of window from the Library. She said she didn't mess with them (other than duplicating and changing the sizes). I've been seeing a lot of strange things going on in 2020.
Thanks for the help!
Nachricht 9 von 12
keri_salim
I hadn't looked at the casement yet, only the sliders and I was expecting to see something like that in the Family editor. I'm pretty sure all of the windows were from Revit itself so it's a mystery. Although, I swear students close their eyes and just start hitting buttons!
Nachricht 10 von 12
keri_salim
als Antwort auf: syman2000
Worked that way too. I just added another slider from the Library and it was doing the same thing. Very strange indeed.
Nachricht 11 von 12
syman2000
Yea...the mutin family is using swappable family type. This basically replacing swap family with another. If the mutin family shared the same category as trim, user can accidentally replace the mutin with trim family. This is why you get weird trim display at the floor. It won't show in course but will show up in medium to fine detail. So if students want to turn off the mutin, make sure they use this type parameter.
Nachricht 12 von 12
Kosmic_Volk
I don't want Muntin patterns in my windows but when I change that it was having the ghosting issue. Deselecting Muntin Visibility under graphics under the edit type settings, took care of this issue for me.
