Hi everyone, I just have a problem creating slanted walls on my student version of Revit 2020. It doesn't seem to have the Cross-section instance on the Properties at the left side of the interface which gives you a Vertical or Slanted option for the selected wall. Is there anyone here that has the same problem? Could this be a feature that isn't available on the student version?
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
you can refer to these LINK and LINK and see if helps. thanks
When you tick on the Room Bounding parameter for a model element, Revit uses the element as a boundary for a room. This boundary is used to compute the area and volume of the room and does not configure for slanted wall. thanks
Thanks for the reply. With a bit more research, I figured out that the feature I was looking for has only been adapted to the latest version (2021). Although you can actually do a slanted wall by creating an In-place mass and applying a wall on it, as instructed on the youtube video you have posted. Thanks again, mate!
no worries, glad to help. thanks ![]()
