Revit 2020 - Software Crahses
5 ANTWORTEN 5
Nachricht 1 von 6
372 Aufrufe, 5 Antworten
Every time my computer goes to sleep. Revit crashes and I loose any unsaved work.
I have done all the updates and restarted my computer.
Any suggestions
thank you
Tags (1)
5 ANTWORTEN 5
Nachricht 2 von 6
RobDraw
als Antwort auf: Anonymous
Change the settings so that your computer doesn't sleep.
Rob
Nachricht 3 von 6
Caffeine.
Nachricht 4 von 6
Yes, I've had the same issues as well.  I'll walk away for 10 miuntes, the computer goes to sleep and revit has closed all unsaved work is gone.  No error messages, just gone.  I am looking to see if it can be a hardware issue but my machine is ISV certified with Autodesk Revit.  Will post if I can track this down....
Nachricht 5 von 6
RobDraw
Sounds like you need to adjust the sleep timer?
Rob
Nachricht 6 von 6
Viveka_CD
@Anonymous  Did you generate a CER?
Can you share a journal file to test further?
Please see this article for recommendations: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-Troubleshooting-Crashes.html
