Hi Guys,
I am working on Revit 2020.
workstation : 1, Intel i7 6700qh 2, Intel i5 9600Kf
Ram 16gb Ram 16GB
GTX 960m 4gb AMD RX 5700 8gb
While i am working in the floor plan Revit is very slow when zooming or moving in floor plan.
I am having a problem with the Revit performance on both my workstations and actual performance when im using revit is on 20% or less Ram memory maximum usage while im using revit is 2gb .
I tried to increase my virtual memory but problem still persist.
If you got any solution to overcome this issue please advise me.
Do you have a lot of Revit links or CAD links in your file? Also check and see how many errors you have in your file.
Do you have CAD links, Revit links or large file size complicated family?
i dont have any links , and no i donh have any large family i think
if you can try open my project? if its project problem or some hardware or software issue.
in link bellow you can donwload it from cloud
thanks ![]()
https://mega.nz/#!kSBWhYgD!stuJIdB1m5mip_j0Bqump1hLHzGKaOiJWXIoIWZNklY
i don't see any problem with your file it works fine. try to install latest updates from autodesk, updates your graphics card driver to the latest, uncheck your use hardware acceleration from options and go to manage > purge > and delete those families you don't need. please see attached file. thanks
VpT06aWSrjHaFWpx8xlYsxl784GC5FR_0w_r4FM89DA
https://mega.nz/#!LOoQwaTD!VpT06aWSrjHaFWpx8xlYsxl784GC5FR_0w_r4FM89DA
hi, so i tried audit my file - didnt help...
i tried to uncheck acceleration and purge my families it do something because file size reduced to 40mb,
but it still laggy in floor plans and i think it starts lagging in 3d too but when i check revit processs it only takes like 10%processor
930mb RAM never go higher than that
and 7% GPU
so i dont know what is the problem here reallly ...
