Revit 2020 Materials Library has stopped working.
4 ANTWORTEN 4
Nachricht 1 von 5
broganrogers1
627 Aufrufe, 4 Antworten
I purchased a new laptop in September and downloaded Revit 2020.
All was working fine, until a few days ago when the materials library started taking 2 minutes to load each time.
I installed the new update for Revit, which did not help but instead added an internal origin point to every single sheet.
Any ideas as to why it has started doing this?
Many Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
Sahay_R
als Antwort auf: broganrogers1
Please take a look at these resources (in order of importance)-
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Regarding the Internal Origin point, it can be located and unchecked under Site in VG.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 5
broganrogers1
als Antwort auf: Sahay_R
Hi thank you for your response.
Unfortunately the render settings are already set to draft setting and my current project was made in 2020 not updated from a previous version of revit.
I does however have a little exclamation mark on each material to update it?
Nachricht 4 von 5
"a little exclamation mark on each material"
Do you mean the icon indicating that the Material's Rendering Appearance Image cannot be found,
...or, are you referring to the ominous-looking "Legacy Material" icon?
Nachricht 5 von 5
broganrogers1
als Antwort auf: barthbradley
It is the legacy material option.
Many Thanks,
Brogan
