Revit 2020 - Imported IFC From Tekla Will Not Complete Bind Process
1 ANTWORT 1
Nachricht 1 von 2
morrow.bradyWDUY5
143 Aufrufe, 1 Antwort
I've a 80Mb IFC From Tekla. I have inserted this into an empty Revit 2020 model and clicked bind.
However the bind process never completes.
It reads " 100% Processing: Extending changes to Group 'IFC_File_Name' to 1 instances. Pasting elements"
Any idea what is going on?
Interestingly, in the windows folder where the IFC is, I can see a new file called "IFC_File_Name.ifc.RVT.
Beschriftungen (1)
1 ANTWORT 1
Nachricht 2 von 2
Have you opened the resulting RVT? Does it look like the complete model? You can try to run the process based on one of the other IFC options and see if you have any better result.
Steve Stafford
