Revit 2020 Freezing Please fix
5 ANTWORTEN 5
Nachricht 1 von 6
ModelforChrist
1814 Aufrufe, 5 Antworten
There is a serious issue with the latest Revit 2020 that when every time you use the buttons the program freezes for a while. You need to use commands to avoid the freezing but i need the interface.
I tried to uninstall and reinstall but nothing and please autodesk can you bring out a patch to fix this?
I tried to delete ini file that does not work.
Thank you!
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: ModelforChrist
It's really bad.  Just to open a file takes forever. Once its open every time you try to select a tool, save, print, anything.. It freezes. WHEN IS THIS GOING TO BE FIXED? Please.
Nachricht 3 von 6
martijn_pater
als Antwort auf: Anonymous
Don't know, maybe this could help...
...check for video driver updates?
...try to open the file and tick audit box to audit the file.
Nachricht 4 von 6
pendean
Is 2020 fully updated?
Are you accessing a share model on a server? Or is this a local PC located model?
PC specs are...?
Nachricht 5 von 6
skr_khr
After updating to 2020.2.1 Revit freezes at random moments, example when editing roof in 3D view or using save as/family, so It doesn't seem to be specific actions that are the issue. I haven't seen this before latest update, I started in 2020.2. It could be a older 2020 error that has reappeared after the family corruption fix:  https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Nachricht 6 von 6
ModelforChrist
als Antwort auf: pendean
Yes its fully updated when it happened and its local but i am not sure if the latest update has fixed this as there is no update if this has been fixed or not?
