Revit 2020 freezes when exporting to dwg
29 ANTWORTEN 29
GELÖST
Nachricht 1 von 30
LeeDesignCo
5830 Aufrufe, 29 Antworten
When I try to export to a dwg, Revit freezes and the interface turns light grey. Anybody have a fix or know what's causing this?
29 ANTWORTEN 29
Nachricht 2 von 30
nicholas_seibert
als Antwort auf: LeeDesignCo
Hi, sorry for the month long delay on someone responding to you.  If you are still running into this issue can you answer a few questions?
Is this new to 2020? As in you upgraded from 2019 and it didn't used to happen. Do you have any linked DWG's in the file?
Chances are there is something in the model causing havoc or something in that particular view.
I would be happy to help if you are still stuck
Nicholas Seibert
Principal Revit QA
Nachricht 3 von 30
LeeDesignCo
als Antwort auf: nicholas_seibert
Yes, this is a new issue that occured when I upgraded to 2020. I didn't
have this problem with 2019. It happens in simple and complex revit files
and it it's inconsistent, so there are times when it works and other times
when it doesn't. I'm sorry I can't be more helpful.
Nachricht 4 von 30
officeban
I have the same issue with Revit 2020.
Nachricht 5 von 30
als Antwort auf: officeban
I also have this problem.
Nachricht 6 von 30
f.rullon.cosym
Same problem
Nachricht 7 von 30
Mohamed-Nassar
Best Practice for this process try to export CAD drawings on Desktop with English name and close view as u can
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Nachricht 8 von 30
DavidQ9PNL
same problem, any solution to the problem?
Nachricht 9 von 30
filip.kabelis
problem persists for revit 2021.1.2
Nachricht 10 von 30
Lance.Coffey
als Antwort auf: filip.kabelis
Thank you for the update on this @filip.kabelis!
Could you attach a journal file recorded when the hang occurred?
Lance Coffey
Technical Support Specialist
Nachricht 11 von 30
filip.kabelis
als Antwort auf: Lance.Coffey
double post, please delete
Nachricht 12 von 30
filip.kabelis
here it is, and it contains the problematic line
Nachricht 13 von 30
filip.kabelis
So i've tried these workarounds - none of these helped. I've setup new central file with detaching and auditing + compact central. I've found these lines in journal and just deleted and recreated these views, with the same view template, deleted all the .dwg imports from file and from view template - still it freezes at 25%
Nachricht 14 von 30
filip.kabelis
Ultimately only changing View Template did help - seems that I need to recreate it too
Nachricht 15 von 30
I am just encountering the same thing.  I just upgraded from 2021LT to 2021.  I currently have both programs on my computer, and wonder if they are fighting.  I can no longer export form my LT either.
I have 2021LT on my laptop, and that exports fine.
As stated above once you choose how you want it to export, menus turn grey, and nothing happens.  have to CntrlAltDel to get rid of program.
Nachricht 16 von 30
nicholas_seibert
Hi All,
Reading through these messages it looks like we have a few different issues that are resulting in the same problem.
@filip.kabelis thank you for the journal, it looks like Revit is having issues finding custom pattern "_beton zbrojony_2_0" do you know where that pattern is applied? Can you try removing it from the surface and see if the issue resolves itself?
@Anonymous can you send a screen shot of what is happening?  We have seen issues after windows after windows updates that sounds a little like this.
Is anyone here able to reproduce this over and over again? The original post mentioned the issue being sporadic, and for the engineering team, those can extremely difficult and time consuming to figure out. I would like to try and focus on the issues that are reproducible first.
Thank you all for your patients, hopefully we can get this issues figured out.
Nicholas Seibert
Principal Revit QA
Nachricht 17 von 30
filip.kabelis
So I did change this custom hatch to another, and recreated these view templates to similar to the one deleted. Now it seems that it gets stuck on another 2 custom hatches, as it leaves in the export folder one 18KB .dwg file and two 1KB autocad hatch pattern files...
I don't know what to do to make it work, and I need these custom patterns working.
Nachricht 18 von 30
filip.kabelis
I'm adding in latest journal files from my 1,5 hrs of trying to plot .dwg today ..
Nachricht 19 von 30
See attached grouping of steps.
Nachricht 20 von 30
nicholas_seibert
als Antwort auf: Anonymous
@Anonymous
Can you attach a journal?  Ideally the journal is from a clean session.  Just launch Revit, open project, attempt to export.  let it hang for a minute or so, then kill it.  That journal will hopefully have some good info.
Also, do you have the same addins installed on both laptop/desktop?
Nicholas Seibert
Principal Revit QA
