Revit 2020- File Menu button not working.
Message 1 of 12
Have a lab setup in my School. File Menu button will not respond. It works fine under the administrator accounts. The student accounts the button will not open anything.
Replies (11)
Message 2 of 12
ennujozlagam
change your window account type setting to administrator instead of standard and see if helps. thanks
Message 3 of 12
JasonKunkel
Often, it is not permitted to change the security level of users to admin. If this is the case, maybe they can try to set the permissions on c:\program files\Autodesk and update it so Users have Modify permission to that folder and its subfolders. Since Revit is a subfolder it will adopt those settings. That might be enough permissions for the non-admin users to bypass the issue.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
Message 4 of 12
I set the permissions and still did not work.
Message 5 of 12
RobDraw
Did you do that for all project, template, family, and any other folders that Revit needs access to?
Rob
Message 6 of 12
Yes, I gave full permissions to the all autocad folders.
Message 7 of 12
RobDraw
Sorry, you may have posted this in the wrong forum. This is the Revit forum.
Rob
Message 8 of 12
Matt__W
@Anonymous have you seen this AKN article about setting an application to run with admin privileges?
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 9 of 12
That works. However the student still needs to put the domain admin password in to use the program. I tried setting permissions to the AutoCAD folder. Not sure what permissions the admin account is needed to open up the file button. So weird.
Message 10 of 12
I am also having this problem. I am accessing revit via a school computer lab. Does anyone have any other ideas of what we can do?
Message 11 of 12
Run the updates. The latest update fixed the issue.
Message 12 of 12
Thanks! It worked!
For others that are struggling with this problem: I originally checked the
update on the desktop manager and it didn’t show up, had to go to the
website and directly download the update.
