Take a look to the screen capture: i can see the yellow triangle; SEE RELATED ALERTS, but if i click nothing appears, no alert windows, nothing. Also if i try to draw a roof, for example, not closed, i don't see the windows that alerts you and mark where is the problem...
Gelöst! Gehe zur Lösung
Gelöst von Tony_Michniewicz. Gehe zur Lösung
Gelöst von wobrien. Gehe zur Lösung
Sounds like this one here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/simplecontent/content/fin...
Perhaps give it a try?
Let us know.
Kunal Tuljaram Gaidhankar
yes, it seems to be that, in fact i have 2 monitors... but i press the key sequence and just i can see letters in the commands...![]()
No no. Do this when you are suppose to see the error dialogue.
The same issue also on my home's PC! sounds like a BUG... tomorrow i'll try on the other office's PC
Thought I would chime in. Here was another thread reporting the same issue: https://forums.autodesk.com/t5/revit-architecture-forum/revit-warnings-not-working-at-all/td-p/90757... It turns out it is the Revit InfraWorks Update that dropped not too long ago. Remove the most recent "Autodesk Revit InfraWorks Updater" from Windows Uninstall and you can get the warning box to start showing again!
User feedback and testing indicates that this issue is related to the Revit InfraWorks Updater 2020.1 add-in. An updated version that includes a fix for this problem should be available in the near future. Until then, the only known solution is to uninstall the Revit InfraWorks Updater 2020.1 add-in.
I'm still having this problem, I've tried uninstalling the Infraworks and the warning menu still doesn't show up. Are there any further updates regarding this problem. Thanks
In your case it probably wasn't the update. I would suggest starting a new thread since that was the solution here and you need a different solution.
