Revit 2020 Asset Browser Missing Materials
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
brianwclayton1969
1573 Aufrufe, 6 Antworten
I recently downloaded and uploaded the the current upgraded to Revit 2020.2.3 and some of the materials in the Materials Asset Browser are missing (see attached warnings)...This is just an example of one, there are many more....
Any clue on why that is???
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: brianwclayton1969
A few. Let's start here:
This is where my "tiles_travertine_running_24x18in_color.jpg" is located:
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\3\Mats
Nachricht 3 von 7
brianwclayton1969
als Antwort auf: barthbradley
Yes, when I follow the paths, mine are located in the same area. All .jpegs are located in either Mats 1, 2 or 3.
Nachricht 4 von 7
Can you post that image?
Nachricht 5 von 7
brianwclayton1969
I have attached the image as requested. I hope this is the one you are referring to.
Nachricht 6 von 7
So you are saying that the path shown under the "Red Alert" Images goes to one of these images shown in this screenshot???  That's wacko!
...try a different image. If you still see a "Red Alert", try an Image from different location.  Report back results.
...Try the lower resolution duplicate Images found in Mat\2 or Mat\1.
Nachricht 7 von 7
brianwclayton1969
Yes, the paths are correct. It seems when I click on the path in the Material Browser where the RED warning is located and the images dialog box appears and the selected jpeg image is highlighted, once you click "OPEN" then the image is reloaded.
See attached
