Revit 2020.2 update issue
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
mo
2375 Aufrufe, 7 Antworten
I have just installed the new Revit 2020.2 update and its caused an issue with all my plan views on my title sheets. Now all my plan views extend to show the project base point even though I have turned them off previous the update. It also shows the x-y arrows in each view and I cant seem to select it or hide it.
7 ANTWORTEN 7
Nachricht 2 von 8
ennujozlagam
als Antwort auf: mo
try to reboot your machines. is that in the linked file?. thanks
Nachricht 3 von 8
ennujozlagam
als Antwort auf: mo
or you can refer to this LINK and see if helps. thanks
Nachricht 4 von 8
mo
als Antwort auf: ennujozlagam
It does have a linked mechanical file but I don't think that's the issue. I have opened another project that doesn't have any linked file and it happens on both plans and elevation views. Noticed it also shows up on 3D view as well. It does seem to be some kind of new setting that's making it visible in all views.
Nachricht 5 von 8
ennujozlagam
als Antwort auf: mo
Based on your screenshot you are working with workshared files and I'm not sure if this is going to work detached /relinguised all mine all users of the project and try to create a new contral file? And see if helps or uninstall the updates. Thanks
Nachricht 6 von 8
als Antwort auf: mo
Turn off: Site > Internal Origin
Nachricht 7 von 8
mo
als Antwort auf: ToanDN
Thanks that did the trick.
Nachricht 8 von 8
WHarbison_RY
Parallax team made this free plug-in which hides the internal origin in every view.
https://www.parallaxteam.com/internal-origin-hide-ifier/
