This warning keeps showing every time I try to import objects downloaded from BIM object or Revit City, and unable to import. Another similar problem is that this warning shows when I try to save the project. What should I do?
@Anonymous it's possible your model is corrupt, which might explain why you're getting the message when trying to load a family. Does it crash when loading the family into all models or just a particular one?
For the other message, please have a look at the following AKN articles about this and how to set up anti-virus exclusions.
"ENCOUNTERED A SHARING VIOLATION WHILE ACCESSING [FOLDER]" WHEN SAVING A REVIT MODEL
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Encountered-a-sharing-violation-while-accessing-folder-when-saving-a-Revit-model.html
"ENCOUNTERED A SHARING VIOLATION WHILE ACCESSING..." WHEN USING REVIT WITH TREND MICRO ANTIVIRUS INSTALLED
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Trend-Micro-Antivirus-is-blocking-Revit.html
HOW TO SET UP ANTIVIRUS (AV) EXCLUSIONS TO IMPROVE STABILITY AND PERFORMANCE OF AUTODESK SOFTWARE
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Are-there-antivirus-exclusions-I-can-implement-to-make-programs-run-better.html
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
"Import"? Are you using the correct term? What exactly did you download from these sites?
It crashes into all models. Any recommendations on software to tackle the type of problem?
