Revit 2019
Revit 2019
IMCornish
Revit 2019
IMCornish
I knew I was expecting too much when I tried downloading and installing the new 2019 software! Firstly I kept getting a 'Decompressing' problem when the software was about half way through downloading my Building design Premium but after two attempts I managed to at least get Revit 2019 working only to find that when I opened it and tried to update my Title Sheet families I keep getting this dialog!
Anyone got any ideas or should I wait another 6 months before trying again!!!
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
markcalloway
Hi @IMCornish I would have a look at windows event logs at when the errors occurred and see if that gives us any further information. Secondly I would double check that your computer still meets the system requirements for Revit 2019, particularly the version of .Net Framework. Also if you had issues downloading and installing it might be worth running a repair of Revit to be on the safe side. Just to be safe also update your graphics drivers while your at it. Let us know what you find out.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
IMCornish
My system is fine and currently Autodesk is working on this problem thanks
Andrew Robertson
Chartered Architect
Truro. UK
Viveka_CD
Hi @IMCornish
Please see the AKN article on Revit Error: A serious error has occurred when opening a file
Perform an Audit after you open the Revit file and let me know if this helps!
If you have a specialist already working on the case, please follow on the portal and provide a case number here, which will help us to track the status.
