Revit 2019 wont open 50mb file
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
anugouba
535 Aufrufe, 6 Antworten
Hello everyone, I'm having a very serious problem with a particular project file I created a few weeks ago which is about 50mb in size. It's a Revit file created with Revit 2019 but it wont just open, it gets to about 3 percent and then stops moving. I tried other files of the same size and even the ones that are much lager and they all open except this one. The worst thing here is that its a finished project which I'm supposed to have sent to my client. The back unfortunately is gone which is a big mistake I made. I know the whole thing is messy but please help.
Thanks.
Ian
6 ANTWORTEN 6
Nachricht 2 von 7
ennujozlagam
als Antwort auf: anugouba
hello, try to tick AUDIT before opening the file and see if helps. thanks
Nachricht 3 von 7
Corsten.Au
Try Audit while opening..
Corsten
Building Designer
Nachricht 4 von 7
ennujozlagam
als Antwort auf: Corsten.Au
dude, That's exactly what I have said.
Nachricht 5 von 7
Corsten.Au
als Antwort auf: ennujozlagam
As far as I can tell, on my defence :leicht_lächelndes_Gesicht:
we both replied exactly at the same time..
you were micro seconds ahead..
next time I ll try to become flash.
cheers
Corsten
Building Designer
Nachricht 6 von 7
anugouba
Hi thanks for the response, your solution worked and saved me from tons of trouble. I always see that audit button but never taken time to actually k ow what it does. From now onwards I will not take things for granted. But just out curiosity what really happened, why couldn't revit open the file all this while?
Thanks.
Ian
Nachricht 7 von 7
ennujozlagam
Nice...well done,,,, the credits goes to you it should go to those suggested the solutions. Thanks
