Revit 2019 wont dowload
5 ANTWORTEN 5
Nachricht 1 von 6
587 Aufrufe, 5 Antworten
I'm a student trying to download Revit 2019 on my laptop but every time I get to around 4.09 GB, the download will stop downloading, give me a permanent time of 2 days exactly, and whenever I try to wait this out to see if it will start up again, it crashes my computer. It gets rid of my background and turns it entirely blue, my apps and toolbar are gone, and I have to reboot the computer to get it working again. Everything I had open at the time of the crash is still accessible during the crash though. However, when I minimize them, they just go into a tiny little bar in space. I've tried this around four or five times now and yielded the same results.
What can  I do to fix this?
5 ANTWORTEN 5
Nachricht 2 von 6
ennujozlagam
als Antwort auf: Anonymous
hello, first of all checks your computer specs if meets the requirements to run Revit 2019. you may try to look for requirements here Revit 2019 system requirements. thanks
Nachricht 3 von 6
als Antwort auf: ennujozlagam
Hi. Thanks for the quick response. I have previously checked my specs and checked once again to be sure. I do in fact meet all the required specs for both the entry level and the value configurations. Yet this error still occurs.
Nachricht 4 von 6
ennujozlagam
hello, you can try this switch off all your anti virus program and firewall. if you have macfee anti virus try to uninstall first and reinstall later. do'nt use wifi when donwloading. must have direct connection of internet to your PC. and see if this help. thanks
Nachricht 5 von 6
Matt__W
@Anonymous try clearing out your %TEMP% files.
HOW TO DELETE TEMPORARY FILES IN WINDOWS
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-delete-temporary-files-in-Windows.html
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Nachricht 6 von 6
A few tips....do not download over wifi...make sure you have a wired connection.
Don't click the Download Now button.... go to ava.autodesk.com and ask her for the Revit 2019 download, click that you have an existing license...then click Browser Download...  This way it downloads Revit in parts vs all at once.
As mentioned already, be sure your temp file is empty and you have lots of hard drive space to install the program...
