Revit 2019 Title Bar Bug
2 ANTWORTEN 2
Nachricht 1 von 3
morganblum
395 Aufrufe, 2 Antworten
The drawing title in the Title Bar shifts to the right as you add more items to the Quick Access Toolbar, which makes sense when it's above the ribbon, not so much when it below.
Using Revit with latest HotFix also.
This didn't happen before.
Thanks.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: morganblum
Not the behavior I get w/ 2019
@1920x1080 Res.
Nachricht 3 von 3
morganblum
als Antwort auf: barthbradley
Apparently I'm not the only one, see this post: Revit 2019 File Name Cut off at top of application window
Have reproduced the problem on 2 other computers all running at 1920x1080.
Maybe it's a combination of which buttons are in the QAT...
