I have not encountered this in other versions, only 2019. When I select an existing text block with a leader, there is almost always a delay where what I type does not get typed. It doesn't appear later, it just is not getting my text.
Graphics are up to date. System is a 6 core Xeon, 500GB SSD, Quadro 1000, 16 GB ram. It handles everything else really well.
It does it with mine too. Its a video card issue. Was doing in on my Laptop with the 1060 GTX, but the 2070 RTX at work was no problem at all. usually if you hit backspace before you type, it works without the delay :).
I had same symptoms and also delay in tab selection (circulation through selection). What helps was instal graphic card driver from autodesk recommendation site:
https://knowledge.autodesk.com/certified-graphics-hardware
works perfect (AMD FirePro W4300 (FireGL V))
