Revit 2019 Temporary Dimension
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
StefanieSchopp
655 Aufrufe, 7 Antworten
We are working with Revit 2019. When I try to draw an angle ( 2D) the temporary dimensioning for the angle shows the unit meter and a wrong value. I would expect degrees and the correct value for the angle.
Please have a look at the screenshot.
Is there any possibility to change this temporary dimensioning? Or is it a bug?
Stefanie
7 ANTWORTEN 7
Nachricht 2 von 8
ennujozlagam
als Antwort auf: StefanieSchopp
go to manage and check your project units. thanks
Nachricht 3 von 8
StefanieSchopp
als Antwort auf: ennujozlagam
To my mind, that's not the problem. Please have a look at the screenshot.
Nachricht 4 von 8
ennujozlagam
hello, this is what i get with setting.
is there anyway you can share the file, so we can check. thanks
Nachricht 5 von 8
StefanieSchopp
Good morning from Germany,
first of all, thanks for your support.
The setting we have in our project are the same like yours.
You can see it in the attachments.
The cleaned project I added also.
Please have a look of your own.
Thank you very much and best regards.
Stefanie
Nachricht 6 von 8
Kimtaurus
Congrats, you broke Revit.
No seriously, I can't seem to find an explanation either.
What template are you using? When of the templates that come with Revit or your own?
When I use your file, I get the same Result, so it's not Revit but the file itself which causes this problem. Our template shows the correct values.
Even auditing the file doesn't resolve the problem. I also tried Transfer Project Settings, but to no avail.
How long have you had this problem? Only in this project or others as well? Did you recently install a new add-in?
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 7 von 8
ennujozlagam
Hello, I don't think there is a solution for this? I tried everything still doesn't work. I tried to copy the lines into a new project and it works well with correct angles. I'm not sure if you started this project from the beginning or inherited from others? Maybe just someone will have a solution for this. I cannot help much. Thanks Frustrierte Smiley
Nachricht 8 von 8
StefanieSchopp
thank's for yor help.
Now I can be sure, that there is no mistake in our mode of operation.
Best regards
Stefanie
