Revit 2019 Temporary Dimension Errors
3 ANTWORTEN 3
Nachricht 1 von 4
352 Aufrufe, 3 Antworten
Capture.JPGStarted a new project, when I added the interior walls I moved the temporary dimension grips to the exterior faces and changed the dimension, and It gives me an error.  If I don't move the temporary grip there is no error. The error that it gives me is "Can't change dimension segment to this value." Error Handling -View Elements.
I'm in VDI could this have anything to do with it?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Reveal Constraints. Maybe you have a hidden one there.
Nachricht 3 von 4
als Antwort auf: barthbradley
Thank you @barthbradley for your suggestion, but it's a new project with no constraints.Capture2.JPG
Nachricht 4 von 4
dplumb_BWBR
Wish I could help, but all I can do is chime in and say I've seen the same thing.
I couldn't figure out why either, but I tried dragging the wall around, and THEN using the Temp Dims.
Took a few tries, but eventually it let me use them.
