Revit 2019 - stair not showing up
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
phebetam
2397 Aufrufe, 9 Antworten
Since I want to have the stair landing between flights at a certain height (since if I let Revit model automatically, it ended up something like 6' - 4 3/32"), so I modeled the stair runs separately. When I did that, the view, any view, at any scale will not show the next run that should appear as cut plan beyond. I can trick it by using underlay and looking up. and it will show, but essentially does not make any sense. Also, I cannot use the underlay view method in all the sheets.
Is this a 2019 Revit bug? Or it is just a revit logistic?
Thank you so much!
9 ANTWORTEN 9
Nachricht 2 von 10
RDAOU
als Antwort auf: phebetam
@phebetam
The logic is simple...the bottom runs falls outside the view rang. You should be able to manage that stair using automatic landings but if you want to stick to that workflow and need the bottom most run to show, you can
  1. add a Plan Region around the Stair case
  2. and adjust the View Range of that PR by setting View Depth to the level below this way it captures the run below without affecting the rest of the Floor Plan
Nachricht 3 von 10
phebetam
als Antwort auf: RDAOU
Thank you for the comments and solutions. The view region is what I had tried. However, as I mentioned, it is suitable for some view conditions and not all. I am really curious how and why the view can only cut one stair at a time. I might end up not breaking the stair to obtain a logical view.
Thank you again.
Nachricht 4 von 10
RDAOU
@phebetam
You mentioned underlays not Plan Region and/or any view conditions where you have found the latter not suitable...They are intended to give user the possibility to adjust view rang in an isolated region of the plan not sure how that doesn't fit in any context or condition.
Nachricht 5 von 10
phebetam
Hi, apologies, I might have mixed up what I mentioned.  I also talked to the BIM manager about the issue and tried both underlays and plan region methods. But both methods work one way or the other. Overall plans are not suitable to use underlay since everywhere is looking up and cause graphic issues, but the plan region somehow refuses to show the run I intending to be inclusive, no matter I cut at that run or above it and look down.
Nachricht 6 von 10
Your Plan Region must have the cut plane higher than the start elevation of the upper stair.
Without the plan region:
With the plan region:
Nachricht 7 von 10
phebetam
@ToanDN I think I tried, please do let me know if this is not correct. Thank you.
Nachricht 8 von 10
The plan region must cover the upper stair entirely.  You need to stretch it down a bit more.
Nachricht 9 von 10
phebetam
GUESS WHAT, THAT'S IT!!! 2 weeks!!! I spent 2 weeks because the inches of the stair was not covered...by the plan region. Thank you so much @ToanDN
Nachricht 10 von 10
Niravra.BaidyaPWVZM
Please check if all these options are on.
