As the title says, I've rendered a view in Revit 2019. I can Export... the rendering to a file, but cannot Save to Project...
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @matt_landes
Do you have the same project open in another application? Are you trying to overwrite a read-only file?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
OK @matt_landes
I tested your file.
Your sky settings are set to ' transparent' and the 'save to project' is greyed out.
Please change this setting to image or clouds or 'no clouds' etc, and you are able to save the file.
Let me know if this helps and if you have any questions!
Looking forward to your reply update.
Viveka CD
Yup that worked, thank you. Why can a rendering with a transparent background not be saved to the project?
@matt_landes Good to know!![]()
I will see if I can get more information why this happens with a transparent background.
Viveka CD
