hi,
Using Licenced Revit 2019 (I downloaded most recent upgrade about the software from subscription page) I got the same error and the gbxml export procedure generate an xml with no spaces, that represents a non usable file in Dialux.
I understood that this link https://wikifixes.com/it/errors/0x/0x80004005/?gclid=CjwKCAjwo_HdBRBjEiwAiPPXpJFqyo6DyQ8S_F6c6fMql3C...
is only a repair tool that dont solve the issue.
HAve you any suggestion about? how may I solve this problem?
A similar situation occurs in DB link export.
waiting your suggestion, I thank you.
Log vom: Tue, 09 Oct 2018, 16:50:23 --------------------------------------------------------------
Space Name/ID [ElementID] | Error details
1 Atrio aula magna : Si è verificato il seguente errore: 0x80004005 Errore non specificato.
10 Ufficio : Si è verificato il seguente errore: 0x80004005 Errore non specificato.
100 Ufficio : Si è verificato il seguente errore: 0x80004005 Errore non specificato.
Title edited by Richard Rankin: "I have renamed this post to clearly display this is an issue with Revit."
you can try to do a clean uninstall and reinstall again, it could be the installation is not complete, install all the service packs from autodesk and see if helps. thanks
