Hello there,
Now I'm tired with this problem which is I cannot work with any free plug-in for Revit 2019. When I istalled it, everything seem Ok but this plug-in tab is not showing up???, when I try to istall again, the menu show that I have alredy istall this plug-in. So Unistall or Repair only. But untill now, I haven't ever used any plug-in because this error. With addins is OK but plugin is not. (exp: Sofistik BIM tool is not but Naviate Rebar is ok)
Anyone with this same error can help?
Many thanks!!!
I don't see an error. I see a confirmation that it is already installed. Just a shot in the dark, but have you checked your Structure tab and tools?
Hello, make sure that you install plugins with the same version for your Revit 2019 or can run with it. Thanks
I have edited reply with picture, dont know why cannot import jpeg file.
are these autodesk add ins or 3rd party?
if 3rd party have you contacted the developers of the add in with these issues?
I have the same error with Autodesk Inc. plug-in _ Structural Analysis Toolkit 2019, so noone have the same problem???maybe I need to reinstall Revit. ![]()
