i everyone!
I downloaded and installed Revit successfully, however I have troubles with reading the files. These open but I cannot see nothing in my screen (only white background). I tried to modify check settings for elements but all the menu is not active. It's like objects are not shown in the screen so I cannot select anything to modify its properties. I was wondering whether this is an issue with the installation or my window system (Win 10). I have the same issue with Navisworks, It installed but cannot see elements. I tried opening the demo file, but it is still the same.
could You try install Revit latest update 2019.2 see if fix the problem? To be honest I don’t quite get what you mean in your post.
