Revit 2019 mistakenly borrowing worksets & views
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
alex.diebalek
2269 Aufrufe, 9 Antworten
Hi community!
Since our Revitupdate from 2017 to 2019 following issue is occurring:
On occasion, Revit 2019 is mistakenly declaring Project members as borrowers to certain worksets and views without being touched by the respective user at all.Project work is drastically slowed down as certain elements are (unintentionally) claimed and therefore unavailable for other users.
Is this problem mainly due to the synchronization procedure?
Revit seems to forget to relinquish elements, but even by relinquishing manually the above mentioned issue remains.
Any ideas?
Best regards,
Alex
9 ANTWORTEN 9
Nachricht 2 von 10
ennujozlagam
als Antwort auf: alex.diebalek
hello, try to install latest updates from autodesk and see if helps. thanks
Nachricht 3 von 10
Corsten.Au
1. hope theres no one working on the CENTRAL FILE Directly..
Considering the file was updated to 2019.. make sure everyone creates
there own local file...
just a check.. there's high possibility or some other issue..
2. and while working no one making the entire WORKSET Editable... elements should be made
editable.. else other users cannot make any changes...
Best luck
Corsten
Building Designer
Nachricht 4 von 10
RobDraw
I've seen this happen across multiple versions mostly on cloud projects but not for entire worksets.
Is taking ownership of worksets part of your regular workflow?
Rob
Nachricht 5 von 10
Viveka_CD
Hi @alex.diebalek
I see that you are a new visitor. Welcome to the Autodesk community! Smiley (fröhlich)
Did the recommendations by the experts help with your issue?
Let me know if you have additional questions and if you'd like us to test your file.
Looking forward to hearing from you!
Nachricht 6 von 10
alex.diebalek
als Antwort auf: ennujozlagam
Hello!
I did it already, currently Revit 2019.1 running, didn't solve it unfortunately.
Nachricht 7 von 10
Viveka_CD
Hi @alex.diebalek
Can you share the file to test?
I can send you a private upload folder.
Nachricht 8 von 10
alex.diebalek
als Antwort auf: Corsten.Au
Hi ganesh,
nobody is directly working on the central file, as the entire project composition is based on c4r (B360 Design) and everyone is creating local files automatically.
Even though anybody has ever opened the respective Revitfile, Revit mentions that certain worksets and views have been borrowed by them.
Nachricht 9 von 10
alex.diebalek
als Antwort auf: Viveka_CD
Hi guys,
a solution has been found:
The problem was that some checkmarks within the Structural Settings (Analytical Model Settings) had to be turned off, as they were causing those issues regarding relinquishing both worksets and particular views (File attached).
After unchecking those checkmarks is was then possible to synchronize properly (including relinquishing).
Nachricht 10 von 10
Viveka_CD
@alex.diebalek
Thanks for getting back to us! Glad to hear that you were able to resolve your issue.
Related AKN article: Analytical Model Settings and REVIT STRUCTURE- BEST PRACTICES
