Revit 2019 Materials Library
2 ANTWORTEN 2
Nachricht 1 von 3
5598 Aufrufe, 2 Antworten
All of my materials in Revit 2019 are showing up with a "!" and message "For improved rendering replace the current appearance asset in this material with a newer version." I have downloaded the Revit 2019 Materials Library but do I have to manually reassign every material in the library to get any materials to show up?
2 ANTWORTEN 2
Nachricht 2 von 3
Viveka_CD
als Antwort auf: Anonymous
Hi @Anonymous
I see that you are a new visitor. Welcome to the Revit Architecture forum.
Please see AKN article: Message: "For improved rendering, replace the current appearance asset in this material with a newer version” when hovering over materials in Revit
Issue:
Some available materials have an orange icon with an exclamation mark after opening the material database in Revit.
The following message appears when hovering over the icon:
For improved rendering, replace the current appearance asset in this material with a newer version.
User-added image
Causes:
There is newer material available with improved rendering quality.
Solution:
To replace the current material with the newer one, follow the steps YouTube video Revit 2019: Physically-based Material Assets.
This message suggests that replacing the current material with a newer version would improve rendering.
Note: It is not mandatory to replace assets and in some instances newer versions of the material do not exist or match exactly.
See Also:
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Nachricht 3 von 3
hi, yes i have the same issue all the material are old
I pick the material from the new library of Autodesk and I recreate a new library
it is long but after you have a better quality
and I advise you to do not use the old material it could cause trouble
