Revit 2019 - Make a view full size again after tabbed and tiled views
3 ANTWORTEN 3
Nachricht 1 von 4
8654 Aufrufe, 3 Antworten
I used to be able to tile views e.g. side by side and then just double click on the view window banner or head as you call it, and it would then expand to make that view the current and full size view.  How is this possible in Revit 2019?
I tried double clicking on tab, window, name etc and nothing.
I couldn't see this function in help or anywhere else.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Tab Views and Tile Views on the Windows Panel (View Tab).
Nachricht 3 von 4
als Antwort auf: barthbradley
Hi, thanks yep that does work I know, but you have to click on View in ribbon and then that button to do a function that used to be just double click in all previous versions.  I guess I could just use TW keyboard shortcut but still can't understand why they've removed this key function from a double mouse click that I used 100s a times a day
Nachricht 4 von 4
nmarshall
quite frustrating that you cant double click anymore!
TW is the short cut key, so I will be using that.
