Revit 2019 is slow in perspective view when panning
guillermo4JEUL
Message 1 of 51
guillermo4JEUL
Hello everyone, what could be the reason that the pan is so slow and sometime does not even move the view in perspective mode, It gets practically unusable.
Is there something I can do about it?
This happens to me with any project regardless if is big or small and we have high end computers with pretty good specs.
Thanks, I hope there is a solution for this!
Revit 2019.2, Windows 7
Accepted solutions (3)
Replies (50)
Message 41 of 51
Kevin.Sander.SG
Community Visitor
Community Visitor
I changed my Perspective Mode from "Perspective" to "Orthographic" and it fixed the pan issue!
Message 42 of 51
guillermo4JEUL
Hi, That doesn't fix the problem, you just change from perspective to orthographic, the issue is in perspective not in the orthographic, there it works fine.
Message 43 of 51
johnkTVSDW
I just realized I had autocad files/plans imported into the drawing and viewed these cad files in perspective mode, which created the same issue discussed in this thread.
As soon as I hid the autocad files in the view my zooming became normal again.  I might go back to cad file and maybe see the drawing extents, to see if that would help.  But I swore I would never use Autocad again after migrating to revit  : )  I only use as backrounds from another architect.
Message 44 of 51
johnkTVSDW
yep in my case it was def the imported cad files
Message 45 of 51
npimentelTBEVW
Community Visitor
Community Visitor
THIS HAS NOTHING TO DO WITH OUR COMPUTER SPECS!
REAL SOLUTION:
The 3D viewport just glitches by itself!
The way I fixed mine was just creating a new 3D View and reapplying my View Template
I hope this works for you too
Sorry for the font and all but this is a bug that really annoys a lot of people and the direction these answers were going just got to me.
Message 46 of 51
stephen.spikings
We also had a problem with panning a 3D views in perspective mode which included linked .dwg files. For us the solution was to turn off all the .dwg layers which contained text and then normal speeds returned. Not entirely intuitive as 3D views don't show text anyway.
When the text was turned on (but not displayed), zoom extents pulled out further than when turned off, even though all the text was within the linework. Also, after turning text back on, panning would work as expected until you zoomed in or out, following which, panning would slow again.
Message 47 of 51
Ahmed.ElkhoulyXYWF8
Community Visitor
Community Visitor
This fixed the problem for me. Thanks rodrigo.acker
Message 48 of 51
jhBCN5E
Observer
Observer
I fixed it by deleting the default 3D view and opening it again.
Message 49 of 51
isobol
You are a true hero, thank you.
Message 50 of 51
reynosokruger
Community Visitor
Community Visitor
I'm from Argentina. I don't speak English very well. I had a similar problem, but I found the solution. Go to 1. File 2. Options 3. Steering Wheels and Overrides, and you'll see the "Move Parallel to Work Plane" option. The factor can be changed from 0.1 to 50. I had it at 0.1. I changed it to 25 and it works perfectly. It had nothing to do with the hardware or the display type. I hope this helps. Best regards.
Message 51 of 51
reynosokruger
Community Visitor
Community Visitor
Go to 1. File 2. Options 3. Steering Wheels and Overrides, and you'll see the "Move Parallel to Work Plane" option. I had it at 0.1. I changed it to 25 and it works perfectly. Bye!!
