Revit 2019 how to use/unlock locked material libraries
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
4996 Aufrufe, 4 Antworten
I am nowadays using Revit 2019 instead of 2018. I like 2019 very much, but I am having some problems. The biggest one
is that I don't know how to use the locked material libraries. I wanted to change materials in a wall, when I found out there was no insulation available. I searched on the internet and read that there was a locked library where I could found more materials. But the problem is I don't know how I can use these. I hope someone knows how to deal with this problem and got a solution.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Are you talking about Assets?
...create a new material and assign an Appearance, Thermal or Physical Asset to it from the Asset Library.
Nachricht 3 von 5
als Antwort auf: barthbradley
Yes I think I am. I don't know what Assets mean, but I saw it on my screen when I tried to use the materials.
Nachricht 4 von 5
...look through the assets, or use search keywords to find an Appearance Asset you like and then apply that asset to your new or existing material. Easy breezy.
...drill down from here: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Nachricht 5 von 5
You are right, very easy. Thanks a lot!
