Whenever we try and access the Default 3D View in our file the whole program crashes and says that an "unrecoverable error has occurred" and that the program will be terminated. However all Camera 3D Views do not cause the same issue. I have absolutely no idea why this keeps happening, no matter what we are trying to do to fix the issue.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Are we talking the default "{3D}" view. Sometimes it gets corrupted. Delete and recreate it. Are you able to?
I'm not able to recreate any 3D views. As soon as click 3D default view, it appears the same message
solution did not fix my problem. The Revit file was stripped of views sheets etc. Nothing to delete. Has to have a cache somewhere. Think ill start with temp folder
I hate that I post to just do what i was thinking. Delete temp files resolved this.
Thank you! I used your suggestion (deleting the default 3D View from my project browser, then recreating)
Worked like a charm. Wish I had seen that before I spent so much time purging, saving a new central etc.
