Hello !
I am trying to install Revit 2019 on my new Surface laptop windows 10 pro.
After going thru all the steps, it fails to install Revit and another file, offering error 1603.
enclosed is an image of the message, if someone know what i should do next, please let me know. I am not very sharp with install etc, something I've never learned.
Thank you in advance! MAX L
you can refer to this LINK and see if helps. thanks
thank you for your response!
would you be able to advise a little further-
here is an image of the error i found in the install log
and here are the programs installed- would you advise which one or ones I should uninstall in this case?
Thank you so much for your help,
MAX L
So I deleted all 4 Microsoft c+++ redistributable, etc. from my programs. i was hoping, per the tip, that the revit Program would load, but same as before. , i hope i did not make a huge error!
